2002 Audi Quattro Engine Oil Pressure is on,
117,000 MILES • 6 CYL • AWD • AUTOMATIC
MTREG
I just change the oil a couple of days ago, it was running fine until yesterday, when the engine pressure light came on. I would beep then go off. Then 5 to 10 min later it would come on again
Jan 21, 2010 at 11:23 AM
DRCIENCIA
[quote:1902adc645="mtreg"]Engine Mechanical problem
2002 Audi Quattro 6 cyl All Wheel Drive Automatic 117000 miles
I just change the oil a couple of days ago, it was running fine until yesterday, when the engine pressure light came on. I would beep then go off. Then 5 to 10 min later it would come on again[/quote:1902adc645] you problem is the pickup oil strainer need to be clean drciencia
Mar 8, 2010 at 2:09 PM
