2001 Audi Quattro HELP!! 1st gear noise
130,000 MILES • 4 CYL • AWD • MANUAL
MGHMCDON
Having just spent $7000 to put in a new engine, I'm almost sick asking this question!
So out of the blue my Audi TT started making a noise initially in just 1st gear, now in second too. I wish I could explain the sound, but it's like a grinding/rubbing/vibration sound (NOT IN THE SHIFTER...everything shifts just fine). It only happens right at the beginning of the gears after I've let the clutch out. But after I've accelerated just a bit, it stops. The sound changes each time a bit...maybe because I rev differently? If I rev a little more than usual before I let the clutch out, it doesn't make the sound. There is no slipping. No jerking. Just this kind of loud grinding like sound at the very beginning of first and second gear after the clutch is out.
TELL ME IT'S INEXPENSIVE OR THAT I CAN JUST DRIVE IT LIKE IT IS...for a long while. I'm out of money to spend on this car!
PLEASE HELP!
THANKS!!
Meghan
May 19, 2009 at 11:38 AM
DR LOOT
  • 2,311 POSTS
Sorry Loot Bug, you have failed to mention if you've checked the oil in the transmission? that would be critical. And I have some other ideas, first of all let me know if the oil is full.
May 24, 2009 at 8:20 AM
