2000 Audi Quattro catalytic converters removal install
JAMESRMURPHY
Engine Mechanical problem
2000 Audi Quattro 6 cyl All Wheel Drive Automatic
I am removing and installing both the catalytic converters on a 2000 audi a4 quattro. I have all four O2 sensors out. I also have both cats disconnected from their exhaust manifolds. I cannot remove the cats from the car the forward cat and flange are not clearing engine compartment. I only have the front end lifted off the ground. How do I get them out?
Feb 3, 2010 at 8:02 AM
2CARPRO JACK
  • 11,533 POSTS
Sometimes if the forward flange wont clear between the body and engine, you need to unbolt the motor mount on that side and jack up the engine until it makes it out.
Feb 3, 2010 at 11:42 PM
