1999 Audi Quattro water pipe
111,400 MILES • 6 CYL • 4WD • AUTOMATIC
DWARIKIKA99
Where the Radior hose is connected to the water pipe, I have whole in that pipe , how can that be repair,
Aug 28, 2010 at 3:04 PM
ERNEST CLARK
  • 1,730 POSTS
The only way to fix this is with a new/used unit. You can not repair the whole, as the cooling system pressure will surely cause another leak.
Also, make sure to clean the gasket surfaces and install new gaskets. If you need more advise, write back.
Sep 26, 2010 at 10:40 AM
