Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Audi
Quattro
Engine Cooling
Leak
1999 Audi Quattro water pipe
1999 AUDI QUATTRO
111,400 MILES • 6 CYL • 4WD • AUTOMATIC
DWARIKIKA99
MEMBER
1 POST
Where the Radior hose is connected to the water pipe, I have whole in that pipe , how can that be repair,
Aug 28, 2010 at 3:04 PM
ERNEST CLARK
Experienced Mechanic
The only way to fix this is with a new/used unit. You can not repair the whole, as the cooling system pressure will surely cause another leak.
Also, make sure to clean the gasket surfaces and install new gaskets. If you need more advise, write back.
Sep 26, 2010 at 10:40 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
