1997 Audi Quattro trans
1997 AUDI QUATTRO
SE1MEK
1997 Audi Quattro 134000 miles
I REBULT THE TRANS AND REPLACED SPEED SENSOR
BRAKE SWITCHES AND THORITAL POSITION SENSOR
I AM STILL NOT GETTING ANY COMMUNICATION TO ENGINE I HAD THE PROBLUM THAT THE PRM WOULD NOT PICK UP . I AM STILL HAVING SAME ISSUE AFTER I SCAN THERE ARE NO CODES
NEED HELP
THANKS CHRIS
Nov 30, 2008 at 10:33 AM
  • 31,937 POSTS
Start to check the power supplies and earths at the ECU, test systems one at a time, check all loom plugs and start checking critical components such as TPI settings, crank and cam sensors with a multi meter, you will need a work shop manual to find the method and get the correct values, start here.
Mark (mhpautos)
Nov 30, 2008 at 10:42 AM
