1996 Audi Quattro Only cold air
152,000 MILES • 6 CYL • AWD • AUTOMATIC
FIREMANDAVE257
I only get cold air out of the heater. I have replaced the AC module and the heater control valve. What else should I check? Do I have to bleed the system? I can feel vacuum at the control valve but have no way of measuring it. Any suggestion would be great.
Nov 22, 2008 at 3:03 PM
  • 31,937 POSTS
HI there,
Check that the heater hoses are hot with the heater on and the engine at normal temp, if not the tap may not be opening, check this first.
Mark (mhpautos)
Nov 22, 2008 at 3:22 PM
FIREMANDAVE257
Where is the tap?
Nov 24, 2008 at 1:45 AM
  • 31,937 POSTS
I will have to look it up.
Mark
Nov 24, 2008 at 7:12 AM
FIREMANDAVE257
Finally discovered that there are twobleeder valves. That didn't work. Broke down and took the car to the shop. Enjoy the donation.
Dec 1, 2008 at 12:49 AM
