Instrument panel lights are off, and the car will not start?
170,000 MILES • 4.2L • V8 • 4WD • AUTOMATIC
MOHAMAD12764
Firstly, I turned the key to the first click but in the second click the car made a voice for 2 seconds, but the engine won't work.
i checked the battery it was too low then i tried again but the same thing
happened.
When I tried for the third time i turned the key to the first click but no lights in
the dashboard turned on
then when I checked the battery again its level was 0.
I charged the car battery using a cable and it charged but still, the same
problem when I turn the key on the first click no light in the dashboard on all
the lights off and I can't open the windows, but the radio is on and i can open
the window using the key and I can control the car's main screen but the
screen on the Instrument panel is off.
Jun 13, 2024 at 8:38 AM
  • 110,248 POSTS
I was always taught to start at the power source when there was an electrical issue. So, here is what I suggest to start: Remove the battery, fully charge it, and then take it to a parts store and have them load test it to make sure we don't have a bad cell inside the battery.
If you want, here is a load test you can try at home before taking it. This doesn't require any tools to perform.
If you have already done this, let me know. Also, what did you mean by you heard a voice when trying to start it? Are you referring to the starter motor or something inside from the radio?
Jun 13, 2024 at 1:45 PM
MOHAMAD12764
thank you for your advice , I will try that and the sound it is like every day when you turn on the engine but here it won't turn on.
Jun 13, 2024 at 7:28 PM
MOHAMAD12764
but if the problem is in the battery why I can open the windows by the key, but I can't open it with the button in the car and why the screen for the radio is turned on and I can check the battery level by it but no lights in the dashboard.
Jun 13, 2024 at 7:36 PM
  • 55,684 POSTS
The battery sounds bad to me, how many years old is it? How did it do on the load test guide?
Jun 14, 2024 at 11:43 AM
MOHAMAD12764
i don't know but it's too old and very weak.
Jun 14, 2024 at 11:49 PM
  • 55,684 POSTS
Let us know after you install a new battery, this guide can help:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Please go over this guide and get back to us.
Jun 15, 2024 at 3:56 AM
