smoking engine
AUDI
ROBMAS
have a 2001 audi s4 that is smoking terribly; 2.7 turbo engine, lost boost power, is it possible the seals are shot causing oil to leak into turbos? and if that happens are the turbos ruined?
Apr 23, 2007 at 6:45 AM
VLADGEISER
  • 66 POSTS
There is a definite possibility that you fried a few seals, those turbos have a reputation for dying as there location exposes them to a little more heat than would be ideal. Was it smoking out of the tail pipe or from under the hood or under the car?
The tail pipe could be a variety of things, while under the hood usually doesn't have much to do with the turbos; while under the car is a VERY bad sign.
The loss of boost pressure is very troubling though, were you able to hear the turbos spinning up or was there a grinding sound, if you heard grinding you most likely destroyed one or more of the bearings in the turbos.
Mar 1, 2009 at 5:00 PM
