audi overheating
AUDI
LOTALUCAS
I've tried replacing the thermostat and i know that it's not the seals. I'm pretty sure it's the water pump but i want to make sure before i go ahead and buy it. there are no leaks and the head gaskets were already changed about a year ago. It's a 1990 audi 90 it has 110 k miles on it, and has a 5 cylinder 2.3 liter engine.
Aug 30, 2007 at 8:24 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a83a1fa943="lotalucas"]I've tried replacing the thermostat and i know that it's not the seals. I'm pretty sure it's the water pump but i want to make sure before i go ahead and buy it. there are no leaks and the head gaskets were already changed about a year ago. It's a 1990 audi 90 it has 110 k miles on it, and has a 5 cylinder 2.3 liter engine.[/quote:a83a1fa943]
no leak for sure check the cyl head
even thow the gasket was changed a year ago save yourself time and$ check it again
good luck
Oct 12, 2007 at 2:45 PM
KARENCAREN
  • 72 POSTS
Definitely you should check the cylinder head. Check it if you have some troubles. If not, then you will be changing the water pump.
Get some cargo liners for your car
Sep 2, 2008 at 1:35 PM
