1995 Other Audi Models No interior heat
1995 AUDI
150,000 MILES • 6 CYL • AWD • MANUAL
SWIDELL
1995 Audi 90, 2.8 v6 12 valve. Over the last six months I've gotten a new timing belt, water pump, thermostat, and recently a new starter. when I got my audi back it had no interior heat. The engine temp is normal and the interior fan runs fine, but no heat.
Jan 11, 2008 at 1:45 PM
FISHERMAN
  • 937 POSTS
[quote:a88e03baff="swidell"]Heater problem
1995 Other Audi Models 6 cyl All Wheel Drive Manual 150000 miles
1995 Audi 90, 2.8 v6 12 valve. Over the last six months I've gotten a new timing belt, water pump, thermostat, and recently a new starter. when I got my audi back it had no interior heat. The engine temp is normal and the interior fan runs fine, but no heat.[/quote:a88e03baff]
Hello !!
Check the heater core valve....
that`s the valve that allows the hot water to enter in to the heater core... see if is fully operational if is good then check your heater core (could be clogged)
let us know what do you find!
good Luck!
Jan 11, 2008 at 2:11 PM
