2004 Audi Cabriolet Malfunctioning.
58,768 MILES • V8 • 4WD • MANUAL
MIKES04S4
I have a 2004 Audi S4 Cabriolet. Last Sunday my car was parked in a parking lot over nite. We recieved alot of rain that nite. Water came up to my doors.
While I was driving my car I rolled down the driver side window. When I got to my destination, I was unable to roll the window back up. Cluster lights started going crazy, alarm went off. It was showing that my trunk was open when in fact it was closed.
Now... a couple of days has passed. I have been able to roll all my windows down. All lights work. Still showing that my trunk is open. I have tried closing and opening the trunk serveral times to get the light to go out. But no luck. I am unable to use my remote
to lock and unlock the car. My guess is that the Body control module got wet during the storm. Is there anyway tha I can take it out ad dry it off. Where is the body controle module located.
Thanks,
Mike S
Sep 14, 2010 at 9:16 AM
MERLIN2021
  • 17,250 POSTS
No body control module. Yours has a vehicle electrical systems control module, and it's under the left side of the dash, did the interior get wet? If not, try looking for any greenish discoloration on external wires under the hood/car. this would be your problem area. An old trick to resetting electronics is to remove the negative battery cable for 5 minutes, but make sure you know any needed codes for the radio!
Sep 16, 2010 at 7:30 AM
