1997 Audi Cabriolet Cooling fans not working
125,000 MILES • 6 CYL • FWD • AUTOMATIC
LDIKUN
  • 6 POSTS
I have noticed that my fans are not coming on causing my temp to rise. I checked all the fuses and they are okay. I do not have any schematics or block duagrams on the car as I purched it used. Is there a relay I can check and where might it be located?
updated 8-11-09
Thank you for sending me the schematic for my fan problem. However, the picture was so small , no matter what software I used to enhance
it did not work! I did find a 60 amp fuse under the steering column and it checked out okay. Is there any relay that you think maybe bad and what might its location be!
Thanks for any help you can offer me!
Aug 9, 2009 at 6:22 PM
  • 75,988 POSTS
Check cooling fan fuse no. 42 60amp
https://images.2carpros.com/forum/automotive_pictures/12900_cooling_fan_audi_1.jpg
Aug 9, 2009 at 6:41 PM
  • 75,988 POSTS
Give me your email addy and I'll send it thru-don't work I'll try another method get back asap
Aug 11, 2009 at 12:54 PM
  • 75,988 POSTS
There's 4 relays involve in the circuit
https://images.2carpros.com/forum/automotive_pictures/12900_cf1_13.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_cf2_13.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_cf3_3.jpg
Aug 11, 2009 at 3:58 PM
