2001 Audi A8 A8 Trans
85,000 MILES • V8 • AWD • AUTOMATIC
AUDI2001
2001 A8 , 85k mi No pressure in reverse, forward OK. Had the tran fluid and filters changed seemed ok now same problem after 100mi
Kirk
Aug 27, 2009 at 12:44 PM
  • 31,937 POSTS
HI there,
I feel that this may be a valving problem with in the transmission, possibly a sticky or shift vale, you will need to get this checked by a transmission specialist as they will have the equipment to do the required tests on the transmission to determine this fault .
mark (mhpautos)
Aug 27, 2009 at 12:49 PM
