What are the consequenses if you rotate the crank and cams after removing there timing belt? I must be the only one who has had trouble after a belt change (actually did it to replace crank and cam seals). The belt is aligned properly- I've reset it at least six times. I did move one camshaft when it was disassembled- later I read not to do this- could cause hla bleed down. Would this cause any issues that would make the car not start? Turns over but wont start.
Nov 19, 2007 at 9:43 PM
