1997 Audi A8 SUNROOF
97,000 MILES • V8 • AWD • AUTOMATIC
VENJENS
My barttery has gone dead on me twice and besides losing my radio, when I jump start the car the sunroof goes to full open and will not close. Last time I took this to the dealer and they said they needed to reset the motor under the front ceiling compatmenrt for the controls for the sunroof and interrior lights.
Can you please forward me the procedure for doing thiis so I do not need to go back to the dealer again.l I have the instructions for reprogarmming the radio.
Apr 5, 2009 at 9:15 AM
DAVE H
  • 13,383 POSTS
Hello. thanks for the donation .. much appreciated Hope this helps .. let me know ! Sunroof motor, removing and installing NOTE:The sunroof must be closed to remove or install the sunroof motor (cable mechanism and sunroof motor must be in zero position). NOTE:The following list refers to Fig. 13 . Cover For interior light Unclip in downward direction Cover For sunroof motor Remove bolt -8- and pull out of clips toward front. Torx(R) bolts (3x) 3 Nm (27 in. lb) Harness connector At sunroof motor Disconnect harness connector. Sliding roof motor Harness connector For interior light Disconnect harness connector. Harness connector For sunroof motor Disconnect harness connector. Bolts (2x) Fig. 13: Identifying Sunroof Motor Components Courtesy of AUDI OF AMERICA, INC.
https://images.2carpros.com/forum/automotive_pictures/266999_audi_7.jpg
Sunroof motor zero position, adjusting Motor is removed Harness connectors connected Move rotary control to "roof closed" position. Sunroof motor runs to zero position and switches off automatically. Install motor in this position with sunroof closed.
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_442.png
Apr 5, 2009 at 9:49 PM
VENJENS
I am finally getting around to the repair of my sunroof that I sent you back in aoril. The information sent is vague if yu read yourself. I see no help in accomplishing what Audi told me at the time versus what yuou sent.
FYI
Jul 1, 2009 at 8:31 AM
