AUDI A6 ENGINE VIBRATIONS
EAGLEICE
Hi, I have an Audi A6 (1998) and engine vibrates erratically whether parked with the engine running and when driving. It started few days ago after it run out completely out of petrol and have to fill by the gallon. I stiil use it for short distance hoping that the vibration would stop, sometimes when i step on the gas i feel that there is hesitation or lack of power. Im thinking clogged injectors any ideas pls help....
Nov 10, 2007 at 4:17 AM
BLACKOP555
  • 10,386 POSTS
change the fuel filter and see if that helps it any, if not perform a fuel pressure test, your pump may be dieing.
Nov 10, 2007 at 5:48 AM
EAGLEICE
thanks i really appreciate your help. I will try that and let you know of the outcome.
Nov 12, 2007 at 7:57 PM
