I HAVE A 98, AUDI A6 WITH A 2.8 ENGINE AND IT HAS 125,000 MIL. wich is overheating the recnt parts that i replaced was the engine coolant tempeture sensor ( I replaced the coolant sensor becuse thats the only code that i recived from my diagnostic reader ) and i also replaced the thermastat and finally i replaced all of the coolant hoses.
as i drive the car on the freeway for about 15 min the heat gauge arrow stayes in the middle of it and whene i have to stop at a intersection the arrow markes hot but whene i get moving agian it goes back to the middle and when in done using the car it goes back to hot agian.
the diagnostic read is also reading a missfire, and in the same cylinder where it,s missfiring there is a leak of oil in the spark wire hole its not the gasket thats connecting the block to the head its anther diffrent gasket
what i replaced in this section of the engine is the spark plug the spark wires and tha coil assembley and finaly i replaced the battire
thanks
thanks
Aug 12, 2007 at 7:20 PM
