2004 Audi A6 SMOKE
88,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAIO
I HAVE JUST NOTICED THAT WHEN I LEAVE THE CAR IDLE IN NEUTRAL I START GETTING WHITE SMOKE OUT OF THE EXHAUST BUT WHEN IM DRIVING I GET NOTHING REALLY THIS IS WHEN THE ENGINE HAS WARMED UP AS WELL...KIND REGARDS
Oct 27, 2010 at 12:47 AM
LEGITIMATE007
  • 5,121 POSTS
well when you idle the engines vacuum is at its strongest, And white smoke is an indication of coolant burning in the combustion chamber, what I am thinking is, the intake manifold is faulty, and when you idle the vacuum is so strong that it is pulling coolant into the combustion chamber. to be sure that the manifold is the problem area, have the system pressure checked, this will help locate the compromised area(leaking area).
thanx
jody
Oct 27, 2010 at 2:05 AM
DAIO
I understand what your saying but i dont seem to be losing any coolant according to the level..Is there such a thing as a crankcase breather filter on the A6 and if so could it be the cause because its blocked..regards
Oct 27, 2010 at 3:18 AM
LEGITIMATE007
  • 5,121 POSTS
Yes, there should be a pcv valve at the back of the intake manifold, and remember it only takes takes very small amounts to cause this unless there are huge gusts of non stop smoke coming out.
Oct 27, 2010 at 2:37 PM
LEGITIMATE007
  • 5,121 POSTS
Check the brake fluid too, sometimes a faulty valve will allow brake fluid to be vacuumed into the system
Oct 27, 2010 at 2:41 PM
LEGITIMATE007
  • 5,121 POSTS
Check the brake fluid too, sometimes a faulty valve will allow brake fluid to be vacuumed into the system?.
Oct 27, 2010 at 2:45 PM
