2003 Audi A6 lights out
RDXWKPR
Electrical problem
2003 Audi A6 6 cyl All Wheel Drive Manual
My driver side head light is out. Tested the bulb, works fine. Tested the voltage on both sides, it's at about 5 volts. What else can be wrong here?
Aug 16, 2008 at 6:24 AM
KHLOW2008
  • 41,812 POSTS
Hi rdxwkpr,
Check the headlight fuses, one could be blown.
Aug 21, 2008 at 3:14 AM
RDXWKPR
But if I have the same voltage how could a fuse be out? I will check that out.
Thanks
Aug 21, 2008 at 6:50 AM
KHLOW2008
  • 41,812 POSTS
Hi rdxwkpr,
Each side uses separate individual fuses and both circuit are interlinked so when 1 fuse blows, power is now shared by both with one side in reverse flow thus 5 v is present and not 12 v.
Aug 21, 2008 at 12:21 PM
