2003 Audi A6 gearbox
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
COLINP
gearbox not responding when i press accelorator
Nov 25, 2008 at 7:05 AM
  • 31,937 POSTS
Hi there,
You will need to check the trans oil level and make sure its full, if it is check that the transmission is selecting at the box, if the linkages are OK, you will have to get a transmission specialist to check and report on this problem for you.
Mark (mhpautos)
Nov 25, 2008 at 7:08 AM
