Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Audi
A6
Drivetrain
Transmission
2003 Audi A6 gearbox
2003 AUDI A6
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
COLINP
MEMBER
1 POST
gearbox not responding when i press accelorator
Nov 25, 2008 at 7:05 AM
Experienced Mechanic
Hi there,
You will need to check the trans oil level and make sure its full, if it is check that the transmission is selecting at the box, if the linkages are OK, you will have to get a transmission specialist to check and report on this problem for you.
Mark (mhpautos)
Nov 25, 2008 at 7:08 AM
Add image or video
Ask a new question
Check engine light
Engine won't start
