2003 Audi A6 Alternator/Battery
80,000 MILES • 6 CYL • AWD • AUTOMATIC
VXR137
I recently had a battery light come on the cluster in my car. The battery gauge was reading 12 volts. Normal voltage is aroud 14. I would rev the RPM's so that the battery would go to normal voltage. I took my car to the closest Audi dealership and they told me I needed a new alternator and battery. SO I changed them. Alternator was covered by extended warranty, battery was not. After a couple weeks, the battery light came back on, took my car back to the dealership and they told me that I needed a battery harness.
I work at a dealership and I had a technician look at my problem. Tested the battery and the battery was testing at 14 volts. He thinks that I have a "Lazy Alternator." Is there any way I might be able to get feedback for this problem?
Mar 26, 2009 at 4:00 AM
  • 75,988 POSTS
Get the alternator load tested if okay check wiring and the charge indicator
Mar 26, 2009 at 10:28 AM
