2002 Audi A6 Turn Signals/Blinkers solid light
56,000 MILES • 6 CYL • AWD • AUTOMATIC
MONTANAMOOSE
I have a 2002 audi a6, a few months ago the blinkers started stared blinking a few times and then stopping in either direction. Then about 2 weeks ago the blinkers stopped blinking all together, they now just hold a solid light in either direction. I have checked and replaced the fuses, and ideas? Thanks
Oct 27, 2008 at 8:31 AM
  • 31,937 POSTS
HI there,
you will need to replace the flasher can, this is the control unit that regulates the flash, it is just a small plug in controller, i don't have access to the data base to send a pic just yet , but your mechanic will be able to do this in just a few minuets for you.
Mark (mhpautos)
Oct 27, 2008 at 9:07 AM
MONTANAMOOSE
So where would i find this part, and what would the name of it be. I could not find anything under the name flasher can?
Oct 27, 2008 at 9:25 AM
  • 31,937 POSTS
Hi there, here in Aust, they are known as a flasher can, but they are often called a flasher control unit, am unsure where they are located on your car but i will check it out for you,
Mark (mhpautos)
Oct 27, 2008 at 9:33 AM
  • 31,937 POSTS
I have just asked another moderator who has access to the data base to send me some information and i will send it on as soon as i can.
Mark (mhpautos)
Oct 27, 2008 at 9:37 AM
  • 75,988 POSTS
Sir-The emergency flasher switch controls the operation of the blinkers-see below EWD
https://images.2carpros.com/forum/automotive_pictures/12900_flash1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_flash2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_falsh3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_flash4_1.jpg
Oct 27, 2008 at 10:03 AM
