2002 Audi A6 DRIVEABILITY PROBLEM
2002 AUDI A6
CHARLES WHITTAKER
2002 Audi A6 6 cyl Front Wheel Drive 130000 miles
Lack of compression Bank 1. Back cylinder shows no compression the other two 60 pounds. Bank 2 shows 180 pounds on all three cylinders. How can I confirm cam timing? The timing belt appears to be tight & in good condition. Ihave the timing mark lined up on the crankshaft pulley and the valve cover removed on bank 1. So far I have'nt been able to get a diagram showing the timing marks for the camshafts to see if they are out of time.
Oct 8, 2010 at 1:15 PM
KHLOW2008
  • 41,814 POSTS
Hi Charles Whittaker,
Thank you for the donation.
The camshafts do not have any markings. A special tool for holding the camshafts is required. It is placed across both cam to hold them in the correct position.
Oct 12, 2010 at 12:03 PM
