2001 Audi A6 Please help.....
2001 AUDI A6
75,000 MILES • V8 • 4WD • AUTOMATIC
DERKANSTORFF
I have a 2001 Audi A6 4.2L Quattro. Recently the AC has not been working properly. Now it is blowing hot air, and my temp gauge moving toward the H mark. Temp warning light indicator came on. Why is it overheating.? Any help would be much appreciated.
Sep 23, 2009 at 3:08 AM
KHLOW2008
  • 41,814 POSTS
Hi derkanstorff,
When overheating occurs, the compressor would be cut off to prevent damage and this would cause the non cooling issue. Your main problem should be the overheating.
Did you check the coolant level in radiator?
Are the cooling fans working?
Sep 23, 2009 at 6:22 AM
DERKANSTORFF
Yes my g12 tank is full, not sure if the cooling fans are working are those easily visible?
Thanks for your help
Dirken
Sep 23, 2009 at 6:28 AM
KHLOW2008
  • 41,814 POSTS
Check cooling system link here for details.
https://www.2carpros.com/how_does_it_work.htm
Sep 24, 2009 at 2:47 AM
DERKANSTORFF
Thanks for the help. The culprit was the fan clutch assembly needs to be replaced.
Thanks again.
Sep 24, 2009 at 3:22 AM
KHLOW2008
  • 41,814 POSTS
You are welcomed and glad to be of service.
Sep 24, 2009 at 4:38 AM
