2001 Audi A6 P411 AND P1413
89,000 MILES • 6 CYL • 4WD • AUTOMATIC
CARLOS EDDIER
I have this two codes on my car. The car runs, but after 40mi/hr it does not have a constant acceleration.
Jul 26, 2009 at 2:28 PM
STEVEW84
  • 673 POSTS
The codes are not showing up on the code list. Is there a description that you have for each code?
Aug 4, 2009 at 11:02 AM
CARLOS EDDIER
p1411 and p1413
Aug 4, 2009 at 11:05 AM
STEVEW84
  • 673 POSTS
The p1411 has to do with the secondary air system output being low. The other I can not find. The acceleration problem you are having could be many things. Lack of fuel pressure, timing, off, or maybe a air miscalculation. Are there any more codes.
Aug 4, 2009 at 11:29 AM
CARLOS EDDIER
no just those 2, but it says that is the Air pump alone with the EGR valve.
Aug 8, 2009 at 7:01 AM
CRYSTAL708
Could be air pump, vacuum not being applied to both EGR valves, solenoid, vacuum tubing. Need to do some testing.
Aug 8, 2009 at 8:30 AM
