2001 Audi A6 6 cyl All Wheel Drive Automatic
I've changed the water pump, thermostat, coolant temp fan switch & flushed it as much as I can. From what I've searched and reviewed, it has been said that if anyone was mixed any other coolant with g12 that it turns into sludge, wondering if that was true. Other than that, I've flushed it by disconnecting the hoses from radiator to motor and flushed the radiator from both ends of the hoses until it was clear and same with motor and still have over heating problem. Also noticed fan doesn't turn on. I've made it turn on manually so I know the fan's o.K. Too me, seems like coolant isn't flowing. Help please, anyone?
SPONSORED LINKS
Friday, July 25th, 2008 AT 5:11 PM
