2001 Audi A6 No reverse when cold
2001 AUDI A6
119,000 MILES • V8 • AWD • AUTOMATIC
TRONTRONDON
My A6 doesn't seem to have reverse until it gets warmed up. After that no issues. It also cuts out when you push the accelerater past the "kick plate". After that the ESP and ABS warning lights come on. Any thoughts?
Apr 29, 2008 at 10:58 AM
2CARPRO JACK
  • 11,533 POSTS
Have the PCM scanned for codes. With both of those problems there should be something stored in the comp's memory. Could be a trans position sensor issue, throttle body (Throttle position sensor) many things
Apr 30, 2008 at 12:31 AM
