2001 Audi A6 How to change my Oxigen sensor bank 1, sensor
91,000 MILES • 6 CYL • AWD • AUTOMATIC
FRANGANCY
I would like how to change the oxigen sensor of my Audi A6 2.8 quattro V6. I would like to know what kind of tolls do i need/? Is it dificult to do it? And How do i do it??
Jul 12, 2009 at 10:15 AM
STEVEW84
  • 673 POSTS
Which oxygen sensor are you wanting to replace?
Jul 17, 2009 at 11:42 AM
FRANGANCY
Hi!!
According the code, is the one located on bank 1, sensor 2. Thank you!
Jul 17, 2009 at 12:33 PM
STEVEW84
  • 673 POSTS
your bank 1 sensor 2 oxygen sensor is on the driver's exhaust after the catalytic converter. all you really need is a 7/8 wrench to undo the oxygen sensor and you need to follow the wiring to unplug it. HTH.
Jul 18, 2009 at 2:41 AM
JHERCHENBACH
I changed out 3 of the 4 O2 sensors on my 2001 Audi A6 2.7T but cannot reach the dirver's side (bank 1) #1 (upper) sensor. Do you gain access by removing the battery?
Jul 20, 2009 at 3:00 PM
STEVEW84
  • 673 POSTS
no, you might have to take some of the intake tubing off to get to it. Its a PITA to get to it. You get to it just like the Bank 2 side. You just have to move what you need to get to it. Are you getting codes for oxygen sensors? Why are you replacing all 4 sensors?
Jul 20, 2009 at 3:15 PM
JHERCHENBACH
Parts dealer strongly recommended changing out all 4 sensors since car has 110k miles on it. Claimed they slowly burn out by this age causing drop in performance and MPG.
We'll try to gain access to bank 1 sensor 1 (the one cited in car's error code message) anyway possible in the morning. Too bad Audi engineers didn't provide a back door to get this normal repair done.
Jul 20, 2009 at 4:49 PM
