2000 Audi A6 Gearbox oil
JONAMAX
Transmission problem
2000 Audi A6 6 cyl Two Wheel Drive Automatic
does my car have a separate gearbox oil sump and if so, where is the refil point?
Nov 7, 2009 at 2:01 AM
MNWNVC
If your auto transmission is like my 2001 A-6 it is filled from underside the transmission and must be pumped up and over a dam after removing a hex plug (large diam.) Use only Audi or VW product. There is no way to check the fluid level from topside.
Jan 8, 2010 at 1:45 AM
