2000 Audi A6 CV joint
85,000 MILES • 6 CYL • AWD • AUTOMATIC
RGOODEN
I am needing to replace the CV joint on the the drivers side, Should I replace the inner as well as the outter? and Should I do both sides Driver and Passanger side?
Dec 16, 2007 at 5:09 AM
  • 31,937 POSTS
Hi there,
I always O/Haul both ends of a shaft at the same time, but don't worry about the other shaft unless it is also showing signs of wear. Some do both some only what need to be done, it's a personal preference really.
Mark (mhpautos)
Dec 16, 2007 at 8:09 PM
