2000 Audi A6 Cold shift
120,000 MILES • 6 CYL • AWD • AUTOMATIC
SUPERFLY2595
When eng/trans is cold transmission hesitates before shifting, usually shifts around 3k rpm if I leave in auto but I manually shift until warm-up. Once warmed up shifts perfectly.
quattro with triptonic
Nov 12, 2009 at 3:17 AM
DOCFIXIT
  • 18,828 POSTS
How much milage on trans fluid? Worn seals inside trans can cause pressure loss when cold also.
Nov 12, 2009 at 7:14 AM
SUPERFLY2595
Approx. 30K miles since ATF and Filter change.
Nov 13, 2009 at 6:44 AM
