1999 Audi A6 no start-cold
GARSENAULT
Engine Performance problem
1999 Audi A6 6 cyl All Wheel Drive Automatic 110K miles
Car starts & stumbles until warm when using starting fluid. Runs fine after warm up...and re-starts fine. Will not start after sitting for 4-6 hours. Replaced fuel pressure regulator..no help
Apr 11, 2009 at 6:27 AM
KHLOW2008
  • 41,812 POSTS
Hi garsenault,
Thank you for the donation.
Problem could be temperature related and I would suggest checking the Engine Coolant Temperature sensor.
Required special tools and test equipment
VAG1551 or VAG1552 Scan Tool (ST) with VAG1551/3 adapter cable
Apr 12, 2009 at 4:16 AM
