1998 Audi A6 Overheating
91,000 MILES • 6 CYL • AWD • AUTOMATIC
LARRY1669
My car was overheating. The coolant temp gauge indicated 3/4 to the right. Oil temp gauge climbed to over 250-270. Repair shop replaced fan clutch. The car is still doing the same thing. Both fans are now working and the coolant level is fine. Thermostat? Water Pump? Easy to replace thermostat?
Jul 18, 2008 at 4:36 PM
  • 31,937 POSTS
Hi there,
I would be checking the thermostat first, as for ease of replacement.. sorry i have never done one on your type of car, but i feel it will not be difficult.
Mark (mhpautos)
Jul 18, 2008 at 5:35 PM
RJJ 1
  • 16 POSTS
to remove the thermostat on this car it requires to remove the timing belt if you haven't replaced the t/belt and water pump it's a good time to replace them also
Jul 26, 2008 at 6:44 PM
