1998 Audi A6 Can it be repaired?
1998 AUDI A6
128,000 MILES • 6 CYL • AWD • AUTOMATIC
NCSURMY
A friend of my son drained the transmission fluid by mistake instead of the engine oil from his 1998 Audi A6 Quattro, after which my son drove the car with little or no transmission fluid for approximately 25 miles. After refilling the the transmission fluid it works fine but occassionally will not shift beyond second gear. He has to shut the car off and restart it to get it to work again. Can this problem be diagnosed and possibly repaired without replacing the entire transmission? Where should I start to try to determine if it is repairable? Thanks.
Apr 9, 2008 at 4:23 AM
DOCHAGERTY
  • 9,606 POSTS
The electronics in the modern German cars is readable for any faults that may have been set when the kids drove it without oil. Do you have a trustworthy Audi repair tech in your region?
Apr 11, 2008 at 9:32 AM
