1997 Audi A6 Misfiring and check engine light
CARREN WILLIAMS
  • 1997 AUDI A6
  • 6 CYL
  • FWD
  • 176,000 MILES
Computer codes identified:
P1101
P1106
P0306
What are the problems and what is the repair?
Monday, January 7th, 2008 AT 2:28 PM
BLACKOP555
  • 10,371 POSTS
P1101 and P1106 are all MAP sensor codes, try a new MAP sensor and make sure the vaccum lines to it and the vaccum tree are all right, also check the eletrical connectors, may be time for a new MAP
P0306 is cylinder 6 missfire. You should change the spark plug, wires, check the coil, coil pack, and listen to see if the injector is buzzing and putting out fuel.
It can cause the MAP sensor codes, or it can be caused by the MAP sensor codes.
Monday, January 7th, 2008 AT 8:26 PM
Related Check Engine Light Content
