damn thing opened on its own and now it won't close!!! Additional problem, is the AC smells like exhaust. Any help here?
Aug 3, 2008 at 11:07 AM
KHLOW2008
✓Experienced Mechanic
Hi Larry Laatsch,
The sunroof problem should be due to a fault in the control module. Try closing it by holding key in lock position witk doors closed and see if it helps.
The AC should be having problem with the air mix/heater.
