Hi there,
Looking at the tool required, I would not attempt to do this job with out on, as I feel that you will have the cams on spring compression and they will not hold timing position with out being locked in, if you have no access to this tool, you may be able to make your own, but don't do anything with out ensuring that the cams are locked in place first.
Mark (mhpautos)
SPONSORED LINKS
Saturday, February 28th, 2009 AT 4:12 PM
