1999 Audi A4 CD Changer and Creak
BOSNIANAC
  • 7 POSTS
I own Audi a4 1999 79000mi 1.8 turbo. I have recently changed battery after which the cd changer is not communicating with radio, cassette and stations are working but cd is not an error apears "no cdc" another problem i have is noise coming from the drivers side, when pressing the break and when accelerating or hitting a bump on the road. it is very strange noise and hard to describe but it sound like creaking doors. if somebody could help me i would be greatefull thanks.
Mar 12, 2007 at 11:09 AM
MERLIN2021
  • 17,250 POSTS
the creacking door sound is most likley lack of grease in a ball joint or tie rod...after you dissconnect a battery in an audi you need to follow the owners manual for setting up the radio...lost the memory!
Mar 26, 2007 at 3:08 AM
Suggested Repair
After a battery disconnect, follow the Audi owner's manual radio setup procedure to restore CD changer communication. For the driver's-side creak when braking, accelerating, or hitting bumps, grease the ball joint or tie rod.
Conversation Summary
A 1999 Audi A4 owner reported that after a battery replacement the CD changer no longer communicates with the radio and shows a no CDC error, while the cassette and radio stations still work. They also hear a creaking noise from the driver's side when braking, accelerating, or hitting bumps. The expert said the noise is most likely from a dry ball joint or tie rod and that the radio must be set up per the owner's manual after battery disconnection because its memory was lost.
