2001 Audi A4 Fuel Gauge Drops
MARVGEE16
I have a 2001 audi a4 1.8t quattro with 70200 mile on it and when I turn it off its at one spot on my gas meter but when I come out in the morning it drops lower than where it was and sometimes when I start driving it continues to go lower but quicker than it should it also has a rough idle for about 2 minutes then its ok can you please help me out and tell me whats wrong
Mar 16, 2007 at 2:24 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds as if the fuel level sender might be having a problem. There is a ground behind left side of dash (brown wire) be sure it has good contact with the body. Besides that the sender wire goes straight to the instrument cluster.Ther is a violet/black wire (sender wire) at the back of cluster. when grounded the gauge should move all the way one direction, if not its the gauge or the wire to it. Has the car ever been tuned up? Any check engine light on?
May 12, 2007 at 1:17 AM
Suggested Repair
Check the fuel level sender and the brown ground behind the left side of the dash for solid body contact. Ground the violet/black sender wire at the back of the instrument cluster; the gauge should move fully one way. If it does not, suspect the gauge or its wiring. Also note whether a tune-up is due and if a check engine light is on for the brief rough idle.
Conversation Summary
The owner of a 2001 Audi A4 1.8T Quattro says the fuel gauge drops overnight and sometimes while driving, and the engine idles roughly for about two minutes. The expert suggests a fuel level sender problem, checking the brown dash ground, and testing the violet/black sender wire at the cluster, while also asking about a tune-up and check engine light.
