afe coldair induction system
MICK BARRON
I just installed an AFE Coldair Induction System
on my 2003 Audi A4 1.8t, everything seems to be fine, however the check engine light stays on, i believethis is because of the increased air flow, however,i would like to be able to turn the light off...
any suggestions
Apr 18, 2007 at 1:33 AM
2CARPRO JACK
  • 11,533 POSTS
Are you sure there are no vacuum leaks between the Mass Airflow Sensor and the engine. Is the Air Intake Temp Sensor in the induction. Doubt if more air will set a ligh unless the PCm cant compensate for it for some reason
Apr 18, 2007 at 3:13 AM
