1999 Audi A4 Window Goes Up Then Down
BUSYBEE
I have an Audi A4 where when the up button is pushed the driver's window goes up very slowly and then goes all the way back down alone. What's wrong with it?
Sep 24, 2007 at 12:17 PM
2CARPRO JACK
  • 11,533 POSTS
Could be either the regulator or the window motor.The best way to verify which is to remove th edoor panel for a visual inspection. If nothing appears wrong, then it is probably the motor
Sep 25, 2007 at 12:52 AM
Suggested Repair
Remove the door panel and visually inspect the window regulator. If nothing looks wrong, the window motor is the likely cause.
Conversation Summary
The driver's window on a 1999 Audi A4 rises very slowly when the up button is pressed, then lowers by itself. The expert says the cause could be the regulator or window motor and recommends removing the door panel for a visual inspection; if nothing appears wrong, the motor is probably at fault.
