My window on the passenger side.Won't go up. Please tell me how to repair myself.
Sep 18, 2009 at 3:50 AM
BLUELIGHTNIN6
✓Experienced Mechanic
when you press the switch can you hear the window motor working?
Sep 18, 2009 at 4:18 AM
AUDILOVEHATE
MEMBER
1 POST
I have the same issue as the original post, and I can hear the motor working when I press the up button, but the window does not go up. I can however, push the window up with my hand once the motor stops.
Jan 4, 2010 at 9:15 AM
BLUELIGHTNIN6
regulator in the motor is bad or there is a bad contact on the switch
