2004 Audi A4 using engine coolant
45,000 MILES • 4 CYL • 4WD • AUTOMATIC
MICHAELMULLINS
I have a 1.8 turbo and it is either leaking anti freeze or it is using it. There is no coolant in the oil and I don't see anything on the inside of the oil cap, I have parked the car in the snow and don't see anything leaking, could it be the head gasket and blowing it out the exhaust?
Thanks
Jan 20, 2009 at 8:48 AM
DOCFIXIT
  • 18,828 POSTS
That's a good possibility do you see white smoke from pipe? If you live in cold climate it would be mush more than you normaly see?
Jan 22, 2009 at 3:36 AM
