2004 Audi A4 Replace right rear tail light
2004 AUDI A4
100,000 MILES • 4 CYL • 4WD • MANUAL
LOONLAKELAD
I have had an ongoing problem with the the tail light in my Audi. How do I get at the light assembly in order to change the malfunctioning tail light?
Thanks , PMC
Aug 24, 2009 at 11:38 AM
DUBTECH
  • 159 POSTS
Open the trunk, you'll see a small circular opening covered by carpet right next to the tailight. Pop the cover out of the way and use either a Phillips screwdriver or 8 mm socket to remove the screw. Once the screw is out the tailight assembly can be pulled off the body and you'll have access to the bulbs.
Aug 24, 2009 at 2:12 PM
