2004 Audi A4 Oil sensor light
86,000 MILES • 4 CYL • AWD • AUTOMATIC
HUGO168
I just had the oil pump replaced yesterday. However, now the oil sensor light has come on. I saw that this light means the oil pressure is low. Could this be related to the oil pump repairs?
Apr 2, 2009 at 12:24 AM
BLACKOP555
  • 10,386 POSTS
was it good right after pump was replaced?
oil pump sensor hooked up properly?
use a mechanical guage and check the pressure and compare it to specs. should be atleast 10psi per 1000 engine rpm.
Apr 4, 2009 at 2:21 PM
