2004 Audi A4 Engine Light, Thermostat fault
UFFDA
  • 2004 AUDI A4
Engine Cooling problem
2004 Audi A4 4 cyl Two Wheel Drive Automatic
Car does not appear to be overheating or running cold. Dealer says about $1000? Tell me this is not so. Is turbocharged. Also when should you replace the timing belt on this engine? Dealer says now (95k) and another $1000?
Tuesday, November 2nd, 2010 AT 9:29 PM
DR LOOT
  • 2,311 POSTS
They had a little bit overpriced but it is the dealer, the last thermostat I replace on this particular vehicle I charged $800 and I guess would charge about the same for the timing belt. Sorry
Tuesday, November 2nd, 2010 AT 11:31 PM
