2004 Audi A4 clutch hydrolic problem
94,000 MILES • 4 CYL • 2WD • MANUAL
COBRAMAN
clutch went soft , wont go into gear w/ running ,
replaced clutch master and slave cyl's vacuum bled ,
pressure bled , have tried alot of ways to bleed system , cannot get any pedal , run almost hole qt of fluid through system. ............can any one suggest
a method of bleeding system?
Mar 1, 2009 at 3:48 AM
DOCFIXIT
  • 18,828 POSTS
Try putting rubber tube on bleeder the other end in container filled with brake fluid. Open bleeder pump pedal till all bubbles out.
Mar 5, 2009 at 1:34 AM
