2003 Audi A4 Unable to start
CSPARKLE
Electrical problem
2003 Audi A4 6 cyl Front Wheel Drive Automatic
Audi will not start. When key is put in the ignition the indicator lights on the dash are displaying normally and it chimes when the door is left open, but the car will not start. The keyless entry will not work either, and once or twice in the past two weeks I've not been able to get the keyless entry to work.
Could the problem be related to a dead battery in the key remote or is it more likely an electrical problem with the car?
Aug 19, 2009 at 4:13 AM
STEVEW84
  • 673 POSTS
Does the car turn over or will it not start? If it won't turn over then you need to check battery, connections, starter. If it will turn over but not start then you need to check what you are missing. Spark, fuel, inj. pulse, compression.
Aug 20, 2009 at 12:39 AM
